Etienne avatar image
Etienne asked
Dongle bluetooth impossible de changer le code
Bonsoir, j'ai le module Smart dongle qui se branché sur le port de mon onduleur Phœnix. Il demande a changer le mot de passe, ce que je fait mais a chaque fois que je quitte et reviens sur l'onduleur il me redemande toujours de changer le code car le code est toujours 6x0. Donc le Smart dongle n'enregistre pas les nouveaux mot de passe défini depuis l'application.
Du coup, je suis obligé de le laissé en 6x0 tout le temps. Il y a une solution pour changer ça?
Cordialement.
Etienne.
VE.Bus Smart Dongle
Hi @Etienne
Can you create a service report after changing the pin code and post that here as answer or comment? The procedure to create a service report is described here: https://ve3.nl/VictronConnect_How-to-create-a-VictronConnect-Service-Report
Kind regards,
Thiemo van Engelen
Etienne avatar image Etienne Thiemo van Engelen (Victron Energy staff) ♦ commented ·
Thanks for the answer, i go to Phoenix inverter, change the password from the change password pop-up and returned to main menu for generate service reports.
VictronConnect_report.log
Cordially.
Etienne
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @Etienne
Thank you for reporting this and providing the service log. With this, we found a problem in VictronConnect which indeed prevents it from actually changing the pincode. This will be fixed in a future release. In the mean time, what you can do is go to the product info page (via the settings menu and then the three dots on the upper right) and change the pincode there.
Kind regards,
Thiemo van Engelen
