PeterM avatar image
PeterM asked
Are Muliplus DC terminals isolated from incoming Supply / Earth
I would like to put an oscilloscope on individual Lithium cells that are connected to a Multiplus which has a mains supply connected . The oscilloscope probe "ground" terminal is connected to earth ( as is the chassis of the Multiplus ) If I connect this probe to one of the cells will it create an earth fault? Using a multimeter it seems the DC terminals are isolated from the Multi's chassis , however there is a solid 8V AC voltage between each earth terminal and chassis
wkirby avatar image
wkirby answered ·
I wouldn't like to do it that way.
I'd use one of the following methods:
Use a differential probe.
Use two single probes, invert one of the channels and use math function to subtract the one form the other.
PeterM avatar image
PeterM answered ·
Get that , but would like to use the second channel to caputre the current via hall effect device . I might just run the scope off a battery via a phoenix inverter .
