vangoff avatar image
Smartshunt 500A ringing noise
I have just set up my campervan system and j am getting a ringing noise from the smart shunt 500a. I have disconnected all loads and and the noise remains the only way to stop the noise is by the shunts power cable to the battery.
I tested the noise and it is around 16000-19000hz so it is very quiet high pitching ringing noise. I added a picture showing the noise hz.
Its a Saturday now so ill call my supplier on Monday but wanted to Know it anyone has an idea what the issue could be other then faulty equipment.
Its a new install so I am more than confident with my connections so I'm leaning towards a faulty smartshunt but j could be wrong20201107-144334.jpg
smart shunt
Paul B avatar image
Paul B answered ·
This maybe the cause, open the setting in your victron connect app and check the alarm settings, it MAYBE that a alarm parameter is set and thus its making the alarm noise.
so turn off the alarms and see if the noise stops.
Thanks for the reply, I have all alarms off and i have made sure all firmware is updated. I might try to roll back firmware and if nothing changes I think I'll try a another shunt from the supplier
bore avatar image
bore answered ·
im also getting this issue
