Is there anyway to link the Smart BatteryProtect into a VE.Smart Network?
I was hoping to be able to trigger it from the SmartShunt at a specific state of charge.
Thanks!
Thanks!
It's also a shame that battery protect can't reed battery temperature from battery sense and disconnect the charger with over temperature.
@Fra you could use a Normally Closed thermal switch glued to your battery.
Do I use it to drive the smart Battery protect?
@Fra use in place (or added in series) with the switch (or std link).
Victron BatteryProtect product page
26 People are following this question.
