What is the correct way to install the smartshunt on my battery bank ?!
I have 2 battery (12v) in parallell, and 2 VE Blue Smart 75/15 charges (synchronize charging)
Br
Marcus
Br
Marcus
The shunt has to be connected in the negative wire that goes to your loads/chargers.
Hi Marcus,
It depends a bit on what you want. You can see your 2 parallel batteries as 1 battery. They cannot be monitored seperate from each other so don't stare blind on that. If you don't charge the batteries from an alternator you can use the diagram on page 9 of the manual. Make sure to set Setting 69 (Auxilary input) to Starter battery or Temperature even if you do not use it (it will give you an error regarding midpoint voltage error if you don't).
Hello Pieter, and what about the positive VBatt+ when using 2 parallel banks? Does it matter on which of both batteries it is? Same as where the shunt Battery minus is connected to or is it better to use the plus of the other battery for more accurate values? My problem is that the 2 batteries aren't near each other (there is a motor in between ;-) ) so when there's is not a huge difference, I prefer all connections to one battery.
27 People are following this question.
