hi there. i'm about to configure my back up system, and i trying to find pros and cons of batteries. At first glance i found BYD LVL and BMZ ESS. Any tips ?
Greetings
mrc
Greetings
mrc
Hi there I have done loads of research also, I would recommend firstly the victron lithium batteries expensive but definitely worth it, next my choice would be battleborn lithium batteries definitely consider these two, I have watched and read so much about them, flooded led acid are older and heavier and much much less charge cycles than lithium, agm batteries are also good but and aged chemistry like led acid or enhanced flooded lead acid, if funds are not an issue for the install I would go for lithium, the initial outlay is more but the life and cycles pay for them selves in time in what I have learned.
Hope this helps a good bit.
Thanks David
23 People are following this question.
