I have a new Venus GX which does not appear as a wireless network. Is there a reset available for the device? I also tried connecting to the original IP 172.24.24.1 via the LAN connection so I'm clearly missing something.
Thanks
Mitch
Thanks
Mitch
You have to enable Wireless Access Point in settings --> WiFi --> Create Access Point
You have to connect via LAN first. Best on a LAN with a router and DHCP. You will se IP of your Venus on the DHCP servers address lease table then.
Regards,
Markus
4 People are following this question.
