jose-julian avatar image
jose-julian asked
Does not draw voltage mppt blue solar 75v / 15
Good afternoon. I have a regulator connected to a solar panel and a battery. It has been working perfectly for me to light two 12v bulbs in a country house.
I have noticed that there is no voltage coming out of the LOAD output. I disconnect the fuses from the loose board the battery and reconnect everything. It takes voltage out of LOAD for 3 or 4 minutes and stops doing it. I have looked at the fuse on the regulator and it is fine.
I discard the battery because I have tried two and the same thing happens to me.
What can happen to him?
Thank you very much
BlueSolar PWM
@jose julian
What are your settings for the load output on the mppt?
jose-julian avatar image jose-julian Alexandra ♦ commented ·
no lo se, pues no tengo el cable ni nada para saberlo.
Como puedo darte ese dato?
Alexandra avatar image Alexandra ♦ jose-julian commented ·
If your have a multimeter you can check your battery with it.
https://www.victronenergy.com/accessories/ve-direct-bluetooth-smart-dongle
This will make your life easier with victron connect.
Are there some jumpers at the bottom, these can set cut off voltages.
A manual may also help.
https://www.victronenergy.com/solar-charge-controllers/mppt7510
davidq avatar image
davidq answered ·
More details please. Panels and thier configuration and batteries. You mention MPPT in title but have tagged the question under PWM. Which is it? Dave
