lachlan-watt avatar image
lachlan-watt asked
Can the multiplus with ccgx override a bmv relay via ve direct?
We have a multiplus with ccgx as a backup power supply that is monitored by a bmv via ve direct cable , when battery capacity reaches 95% the bmv alarms and triggers a charge light.
Is it possible with programming that when the multiplus is turned on it will override the bmv alarm and relay?
I understand this can be done with extra wiring but am trying to avoid this.
MultiPlus Quattro Inverter ChargerBMV Battery MonitorCCGX Color Control
Paul B avatar image
Paul B answered ·
As far as I am aware you cant control a BMV relay remotely from a venus or multiplus unit
