richard-3 avatar image
richard-3 asked
Victron Phoenix 12v-50a Charger
Hi The Victron Phoenix 12v-50a Charger has 2 x main battery charging output circuits I have 2 x 12v 230Ah batteries connected in parallel my question is, do I use both circuits and connect one to each battery or do I just use one circuit which would connect to both as they are wired in parallel ?
Thank you in advance
Richard
battery charging
Henk avatar image
Henk answered ·
Just one, the Phoenix outputs are independent circuits, but if you use on two separate battery banks you will use both outputs, limited overall output 50A on both circuits
