brians avatar image
brians asked
CCGX stopped communicating with Multiplus 24/3000
Day before yesterday out of the blue my CCGX showed the Multiplus as OFF with no usage data on AC Loads side.
I did the following
Upgraded both CCGX and MP to latest firmware
Power cycled both, multiple times including turning off the MP at the DC source
Verified that I can talk to the MP via my MK3, both direct to MP and via the second port on the CCGX while the first port is connect to the MP (read about that in another post)
Any other suggestions?
CCGX Color Controlmultiplus ve.bus
brians avatar image
brians answered ·
so an update, I can connect the mk3 usb to the usb port on my ccgx and the ccgx will see the multiplus with the same cat 5 cable. In addition, if I power off the MP will the MP is plugged into the ve bus while the ccgx thinks the mp exists (after unplugging via the usb) the mp will not power on until I unplug the cat 5 from the ve bus.
Hi @brians@fl240.com
Did you unplug the MK3 from the Multiplus?
brians avatar image
brians answered ·
yes, it is unplugged and always has been.
ok, and if you connect to CCGX through MK3/usb cable (without any other ve.bus connections to Multi or CCGX), does it work normal or not?
(sorry you texts are very difficult to read)
CCGX Product Manual
CCGX Product page
