craig-westlake avatar image
craig-westlake asked
Help with charging when connected to AC
I hope someone can offer some guidance.
I have a multiplus compact connected to a battery bank on my yacht. I also have a MPPT solar charger.
When I plug into shore power the batteries are being charged by the MPPT and not the inverter charger. This is probably a good thing when I am in a marina for an extended period but when I come in for one or two days I want the inverter charger to charge as rapidly as possible and then maximise the soaking time.
As you can see the system as it a stands only is charging at 7 amps even though the batteries are 70% depleted.
Thoughts?
MPPT Controllersbattery chargingmultiplus ve.bus
