pyemarine avatar image
Cerbo GX shows: tanks > No tanks found
Tank entries were shown on the detail databoxes page on my Cerbo GX.
Then suddenly " No Tanks Found" was shown and I have no way to bring them back on display, does not show the configuration in devices either. The tank sensors are switched on in the Analogue I/O menu.
What am I missing ? I tried going back to frimware 2.56 and then back to 2.60 but this looks like a hardware fault, any ideas ?
tank monitor
Hi @pyemarine,
I have a few more questions to help try and troubleshoot.
Can you think of anything else that changed between when they were working and when they were not?
Did you do the installation yourself, or was it done by someone else?
Which tank senders are you using?
Are you able to measure resistance yourself across the tank senders when they are not connected to the CerboGX?
Can you take some photos of the tank senders
Hi Guy
> nothing other than a few powercycles in between connecting and disconnecting the senders during troubleshooting. The Cerbo will be replacing the previously installed Scheiber display monitor.
> I did it myself
WEMA/KUS 33-240 ohm 2 wire resistive tank senders
> Yes, operation is as expected and shows correct reading on the scheiber display that was present on the vessel in it's original installation
> negative, senders are installed in both fuel tanks.
Included some pictures of the Color GX Screen:
Can you please post a screenshot of this Setup menu inside the Tank Sensor (from the main menu on the GX).
pyemarine answered ·
here is another one
Guy, that menu is not available
Did you ever find a fix for your problem? I just had the exact thing happen to a customer’s cerbo. He had 4 tanks showing, then same issue. “No tanks” also none of the corresponding menus.
thanks
Hi Dani. Did you resolve this? My tanks are now not showing. And Analogue IO not an option. Have tried installing new firmware 2.84. No roll back versions saved. Thanks.
