ales-volopich avatar image
Temperature sensor for water
Is there a temperature sensor for water with a connection to Cerbo GX?
Temperature Sensor
jeroend avatar image
jeroend answered ·
You could waterproof a LM335 sensor by using heat shrink tube with glue (probably easiest way) and place that on the bottom of the water tank/reservoir or in the water stream?
I want to check The temperature in outside tank for gray water
I would expect the temperature of the tank wall measured outside would be sufficient unless you have some special requirement ( or you are unable to access the tank wall)?
I would not immerse a sensor unless it is very well waterproofed.
laurenceh avatar image
laurenceh answered ·
If this is a question about hot water tank temperature then I have potted LM335s in small metal tubes. Insulated the connection wires and filled them with epoxy like this.
They can then be inserted into the tank foam insulation or under the tank jacket and will give a reasonable value for the tank temperature. I use three to tell me the temperature at the top middle and bottom of the hot water tank and get a good estimate of how much hot water I have to take a shower.
Built this way the sensors are also robust enough to clamp to metal pipes or surfaces to give a temperature reading.
Laurence
Rob Fijn avatar image
Rob Fijn answered ·
Victron is working to make an interface to connect sensors that give 0-20 mA... then is everything possible. Search the forum for 20mA then you will find the post.
Regards, Rob
sv-unsinn avatar image
sv-unsinn answered ·
is it possible to set up an alarm if the temperature will reach a certain threshold? It would be very helpful for the deep freezer or the water heater.
Best
Stefan
