ejm avatar image
ejm asked
lithium-ion battery warmer
I am going to make a box to put my lithium-ion batteries in and wanted to know if there is a heat pad or heater that will work good to put in the box for keeping the temperature above 32 degrees. So I wont damage the battery when charging when temperatures are below freezing.
Lithium Battery
nicholasnicholas avatar image nicholasnicholas commented ·
Hello! I'll be wrapping my 200ah lithium with a heating pad soon. I'm curious what you ended up using? What wattage and size of pads did you use and what type?
I'm leaning towards a RV water heater pad that has a thermostat built in, but I've been debating on using a better quality of silicone pad with temperature switches to have more control over it.
Thanks!
wkirby avatar image
wkirby answered ·
