gjc avatar image
gjc asked
Best settings for the super cycle battery.
What setting can I use best? The presets in the 75/15 MPPT for Gel Victron deep discharge both use 13,8v for float. According to the data-sheet of this battery 13,8v is the upper limit.
The setting for absorbtion is 14,4 or 14,3v. Well below the upper limit of the battery.
Can I use one of the presets or is it better to make a user-defined setting? I think of 14,5v for absorption and 13,6v for float.
battery charging
Alexandra avatar image
Alexandra answered ·
@GJC
Use the preset then tweak the voltages to suit your battery. It is always best to go with the battery manufacturer recommendation.
Also check with a multimeter to make sure you don't have voltage drop over your cables and you are undercharging. In this case using the upper limits works better.
gjc avatar image
gjc answered ·
Thanks for your advice. For now I did tweak the settings and monitor the voltage and temperature of the battery. That should be safe.
I hope Victron adds standard settings for the Victron Super cycle batteries in the app later as the deep cycle and the super cycle are not exactly the same.
Thanks again.
