marcus-cp avatar image
marcus-cp asked
Can I connect my MPPT Load Out to 12 DC 600w water heater element?
Hi Victron Community,
I want to convert my AC water heater to DC.
Can I connect my 12VDC 600 water heater element to the Load Out on my MPPT Solar Controller to run only when my batteries are full?
Here is my setup:
2 x 375w panels connected to a Victron MPPT SMART 150/60
2 x 175w panels connect to a Victron MPPT SMART 100/30
This is going into my LifePo4 bank 4 x 120ah.
Whats are your thought on programming the two MPPT Load Outputs to act like a dump loads from excess energy created my when batteries are full?
I can put two elements into my tank so have two separate heating elements with thermostats.
MPPT Controllerssolar
seandembrosky avatar image seandembrosky commented ·
I'd love to know an update on this... I have a 100/20 smart controller and would really want to set up a 'dump load' for when my 48V battery array is fully topped off to send all excess solar energy through that 'load' port to direct water heaters. I use a 48V inverter hooked directly to the batteries so the load port is basically unused in my setup and 800+ watts could be going directly to heating water most days if I'm not actively using the system... Please share notes if you have any!
Matthias Lange - DE avatar image Matthias Lange - DE ♦ seandembrosky commented ·
As the datasheet says the load output is only rated for 1A @ 48V so you can only use it to activate a bigger relay.
The 100/30 don't have any load output and the 150/60 only have a relay with max 4A@12V. But you can use that relay to switch a larger relay or a remote contact of the heater.
MPPT Product Page
MPPT Error codes
