paultheboat avatar image
paultheboat asked
old phoenix multi 1809149 hex not charging
A family on the canal has asked for my help. they had 2 paralleled phoenix multis,both 18xxxxx firmware. Now they are trying to use one as a stand alone unit. the unit inverts but does not charge or pass through 230v. it shows 230v input in ve configure.I am using mk2 usb interface,and can change settings successfully but just cannot get it to work. the transfer switch clicks like its ignoring ac. incoming power all good. currently sitting on the bench so not wiring issues. configuration seems to make no difference at all. has anybody out there got firmware for 18xxxx version family?
thanks
multiplus in parallel
