Updated real timr graphics on the VRM are very well done! I like it - well done to the team
Glad to hear @merle.peter@gmail.com, I’ll forward your kind words to the team that implemented it!
Teun
Currnetly if a user has a DC only setup all AC info displayed on screen is redundent. If a DC only setup is required and sufficient then i don't see why that users should get the feeling Victron views their system as incompleat due to lack of an AC component.
Could you pass on my request for there to be an option to customise the view so AC info can be hidden. This will better cater for a users that have and only need a DC setup.
Thanks
Great changes. Many Thanks
Two requests:
Add Active SOC level to battery details...
Can you add a feature that allows us to set our own weather station address (wunderground stationid) for the temperature. Mine is badly inaccurate...
I was thinking about weather station integration just last week.
While a bit premature for a service AI solar forcasting is certainly something victron should be thinking as a future service. They can make moves to position them self to collect users weather data now.
I have the new generation forecast in fronius solarweb.
I have got to say, it’s quite surprisingly accurate, within 5kwh so far even in cloudy weather.
I have created a new question, maybe I should put it in modifications, I was doing a little reading and it seems like the output from Easyweather can be read and duplicated in node red.
mine shows SOC....it gets it from the BMS which uses a Shunt, I guess if you had the SmartShunt it would also show.
I assume some one made a coding error with the Grid Graph, seems to be vertical rather than horizontal
28 People are following this question.
