richardp avatar image
richardp asked
Battery Protect for controlling dump load
I am intending in the future to utilise my excess solar in my van setup to run an immersion heater. Unfortunately due to the layout I cannot easily install any more control cables to utilise the Multiplus / MPPT outputs to control the dumpload.
I have been thinking about using an Smart Battery Protect to operate once over a certain voltage, and also to disconnect the load when underneath the float voltage settings from the MPPT.
With the adjustment the Smart battery protect allows with regards to cut in / cut out voltages I am thinking this will allow plenty of scope for a good working setup.
Has anyone done this, or know of any potential problems in using one in this way?
Many thanks
MPPT ControllersBattery Protect
mark-m avatar image mark-m commented ·
This is exactly what I am hoping to achieve as well, did you ever find an answer?
