solalasolar avatar image
solalasolar asked
Victron 100/30 Voltage Settings for Winner Solar SMF
i have two Winner W280S (280Ah) as a Strip to get 24V for my inverter. Now i want to make a Profile for the correct Voltages for charging them both. Here are the voltages that Winner says they should be:
- Bulk 14,8V
- Absorption 15,4V
- Float 13,7V
so, i think i take them all as 2x. But whitch one is the right one in the profile? There i have:
- Absorption Voltage
- Float Voltage should be 27,4V
- Equalisation Voltage
Thanks a lot for your help!
gr33tings,
Robert
solarbattery system voltage
JohnC avatar image
JohnC answered ·
Hi @SolalaSolar
In 'Vicron-speak' (a generally accepted standard)..
..Bulk is a transitional stage on the way to the Absorb target. There's no setting for it.
..Absorb is the maximum V that's targeted on a normal cycle. Akin to your 14.8V, but that's quite an aggressive level.
..Float is after Absorb is finished (the same in your case).
..Equalize is a maintenance procedure, not done daily, and you may decide not to use it at all. That'll be the 15.4V level you listed.
What you actually choose is largely dependent on what you're doing with your batts, cycling daily or largely as backup (Storage). And of course the batts themselves.
Bear in mind that Temperature Compensation will also apply, so the settings you choose will rise with cold batteries (and vice versa). If the maker doesn't provide their settings for that, then they aren't being fair, and the V settings they provide become 'shaky'.
Aggressive settings can cause longevity issues, and I prefer to take a softer approach. Usually the Victron defaults are fine, say 14.4 Abs/13.8 Float for non-specialized batts. You choose..
And yes, for 24V just double them.
solalasolar answered ·
Hi @JohnC!
Thank you for your time and answer! At this Point i have this Settings:
- Absorption Voltage 29,60
- Float Voltage 27,40
- Equalization Voltage 30,80
Here is a Screenshot of the manufacture Settings. Maybe you can See something there, but it‘s german. If necessary i can try to translate ist. Thank you again for your help!
4 comments
Das wären so laut Hersteller die richtigen Einstellungen, wobei ich die wie JohnC auch etwas hoch finde. Aber wenn der Hersteller das so angibt, wird das wohl stimmen.
solalasolar avatar image solalasolar Matthias Lange - DE ♦ commented ·
Matthias! Gott sei Dank, ein deutscher! Stimmen dann die Einstellungen, so wie angegeben? Danke!
Matthias Lange - DE avatar image Matthias Lange - DE ♦ solalasolar commented ·
Wie gesagt, wenn der Hersteller das so angibt, wird das schon stimmen.
14.8 Absorption, 13.7 Float und 15.4 Ausgleich.
Super, dann ist ja alles richtig. Vielen Dank. Ciao.
