owenski avatar image
owenski asked
Victron Quattro 48/15000/200-100/100 - Best battery technology
Hi, i am a recent purchaser of the Quattro 48/15000 and are looking for a suitable battery bank, ideally 1200ah. As i see it, the options are;
NiFe (needs 40 cells for 48v, large physical foorprint, low powered, unbreakable, huge DOD and recovery, flushed out every 7~8 years, 30+ years lifespan, )
Sealed Lead Acid (limited lifespan, old school tech, all the negatives of SLA batteries)
Sealed Lead Carbon (12 ~ 15 years lifespan, slightly better DOD)
LiFePo (5 ~7 years lifespan, can react badly, on incorrect charging, expensive for the return)
battery
ejrossouw avatar image
ejrossouw answered ·
Hi @Owenski There are lots information out there and even on the forum so I am not going to repeat anything. It is really something that should have already been taken care of during the requirements definition and system design phases.
One key aspect is how will you be using your system? Daily consumption or backup only. That could be the deciding factor.
Personally Lithium is the way to go if you can as it charges more efficiently, has smaller footprint for same size e.g. LA, safer, many are "self managed" with own BMSs etc. etc. To oversimplify it, imagine replacing your phone battery with agm, la or gel equivalents.
Only thing to be mindful of is low temperatures as Lithium does not like being charged below 5 degrees c. Not sure about the 7 year lifespan as often lithium is even guaranteed to still have 70-80% usable capacity after 10 years if used as per the manufacturers specification. My NCM 189Ah is discharged every day down to about 10% during winter (i dont have solar) and can be charged fully to 98% (inbuilt limit) in 4 hrs at 40A.
