oliveoil avatar image
oliveoil asked
How to program equalization with Venus GX, MPPTs and DVCC on
My question: Is there a way to manually equalize or automate equalizing while using DVCC?
My problem: When DVCC is on it seems impossible to trigger equalizing. I have tried via the GX console or directly on the charger via VictronConnect. Without luck. When I switch off DVCC I can trigger equalizing with VictronConnect over Bluetooth on the charger.
My setup:
Island setup. No connection to the grid.
- Battery: 24 V, 900ah lead acid
- Panels: 18 275W. Configured as 2 arrays (east, west). Each connected to a charge controller
- Inverter: Multiplus 24/5000/120-100
- Charge controller: 2x SmartSolar Charger MPPT 150/70. Connected vi VE.Direct
- Venus GX
DVCC settings:
- DVCC on
- Limit charge current 100A
- SVS on
- STS on
Regards,
Daniel
MPPT ControllersDVCCequalisation
MPPT Product Page
MPPT Error codes
DVCC chapter in GX manual
