Matias Käkelä avatar image
Matias Käkelä asked
Help a newbie wiring Easysolar remote switch
I’d like to install a remote switch to my Easysolar 1600. Because I’m a newbie, I’d like to ask for help to eliminate costly mistakes.
From what I gather I could use generic 3 position switch, such as this https://www.amazon.com/Single-Double-Rocker-Switches-SHIPPING/dp/B074XKDH9F to remotely change between on/off/charger only. Am I correct?
The next question is about the wiring. It’s not clear to me to which poles I should connect to which Easysolar inputs (charger, middle, on).
I know that there are similar questions asked before, but they seem to concern Multiplus, which has different inputs (ch, +, on IIRC).
I would appreciate if someone could instruct how to do the wiring (or if I’m completely mistaken and this should be left to professionals).
thank you in advance!
EasySolar All-in-Oneswitch
klim8skeptic avatar image
klim8skeptic answered ·
A pic from the multiplus 1600-70-16 manual.
You need a single pole switch, with 3 positions. ON OFF CHARGE.
The switch you linked is correct.
Matias Käkelä avatar image Matias Käkelä commented ·
Thank you @klim8skeptic! How about the wiring. Can I just connect the leftmost pin to remote switches terminal 1 (charger only), middle pin to middle terminal, and rightmost pin to terminal 3 (on)?
klim8skeptic avatar image klim8skeptic ♦ Matias Käkelä commented ·
correct .
Paul B avatar image
Paul B answered ·
when you take the cover off the easysolar you will see the main board and the override plug. it will be blue in colour and have a existing loop wire in it. remove the loop wire and insert two wires one in each posistion and take these to wires to a switch open ciruits turns the unit off closed turns it on. length is of no real concern
NOTE the easy solar inverter is the same as a Multiplus the easysolar has a inbuilt solar regulator added
Is that different to the “remote switch” connector mentioned in the manual?
The connector I’m talking about can be seen in this picture.
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
