my charger has this cable connections. Red and black is clear. But I can't find find any discription for the orange one.
Can someone help me?
Regards
Regards
You have the "Si" model.
"Si" stands for "start interruption".
This wire gives you a signal (0,5A max) which you can use to prevent your engine from starting as long as the charger is powered.
@Marsupilami I wondered about the orange wire too. I thought it might have been a remote temperature probe for the battery. Thanks for the reply @Matthias Lange - DE. Is the orange wire documented anywhere?
@jrcresawn
No not really, it is only mentioned in the spec sheet.
25 People are following this question.
