Pavel Richter avatar image
Pavel Richter asked
Replacing Venus device in VRM gives access denied message
I exchanged raspberry for octo gx.
Everything works.
But I can't change the Venus unit in the vrm portal.
1) I will create an installation with octo gx. OK
2) I go to the old installation and choose to change the venus unit for the one from the new installation. OK
3) I will write the name of the installation for which I want to keep the data (the old one) OK
4) the message "access denied for this object" appears
Can you advise? Thank you
Venus GX - VGX
Pavel Richter answered ·
solved.
It came from another PC on the first try.
