sunnycoastgreg avatar image
sunnycoastgreg asked
skylla i 24/80/3 erroneous nmea bus readings
brand new skylla i, just installed,
all working correctly - except that displayed current readings when charger in “storage” mode are incorrect.
channel/bank B displays a varying current between 1-2A ... even when bank is disconnected from battery!
channel A/bank A - varies also but by smaller ammount ... however is “corelated” inversely to movement of B. (eg as bank A varies from 0 - 0.5A ... the displayed value from B reduces by similar ammount.
bank C displays constant 0.0.
in case of Bank A & B ... the readings are incorrect - as compared to actual measured current.
Bank B displays ... even when battery disconnected (garunteed zero current!)
readings are displayed on two different raymarine axiom MFD, AND cross checked & verified using nmea2000 bus monitoring disagnostic tool ... the displayed readings on the nmea bus are varying as described and displayed.
when “forcing” the charger into a period of absorption - the displays read a more constant current & displayed agrees with actual measured.
the problem appears to be with display behaviour when charger in storage mode..
Q: is this a hardware fault (in brand new unit).. or software?
Distributor has advised to post question in forum .. before initiaating warranty/return process
Skylla
sunnycoastgreg answered ·
further
have reconfirmed that during “absorption” phase,
the displayed values EQUAL to the measured (clamp meter) readings
so its looking very much like a software related issue with erroneus readings when charger is in “storage” mode ...
