The Pylontech US2000s recommended charge current is 25A. I am using 4 on this system. Do I make the charge current 100A (4 x 25A) in VEConfig ?
The max of MPII & Quoattro 48 is 70A? so then should it be set to 70A?
Yes you can multiply the charge current by the number of batteries. You can check this out in the following article
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
Section 4.
20 People are following this question.
