gill43 avatar image
gill43 asked
Should power drain using a Victron Phoenix multiplus be showing on a Sterling battery monitor
Sterling PMP1 monitor recently fitted by boat yard. Just noticed that when using the inverter (Phoenix compact multiplus 12v 1600va 70A) with a small tool ~ 200W without any engine charging the Sterling unit does not register ay current draw. IS this because the monitor shunt has been installed in the wrong place or is there another reason.
Thanks
monitoring
klim8skeptic avatar image
klim8skeptic answered ·
Perhaps you should read the information. Sterling PMP1
Then contact your installer with your concerns.
