When grid is off the multi is putting out 52.7 hz which reduces fronius output. Mean time the dc mppt and battery are suppling load.
Why is the multi holding the fronius at zero?
Without knowing more about your system this may be the explanation. DC charging is more efficient so the Victron will favor the dc mppt. It is also producing enough to cover loads and battery charging, so at that instance there was no need to use the AC pv which is why it is doing nothing
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
AC-coupled PV with Fronius PV Inverters live docs
Fronius Webinar: Fronius & Victron Energy: Easy system set-up
Fronius Advanced Webinar: AC Coupling with Fronius & Victron (AFR)
Fronius Webinar: Smart rural electrification with Fronius and Victron Energy
17 People are following this question.
