agnieta avatar image
agnieta asked
High absorption en Float voltage by temperature compensation?
I've got a Multiplus 12V/80/2000 with charge setting voltages: Absorption: 14,4V / Float: 13,8V
When it's loading it is charging with 14,7V-15,05V and floating with 14,1V (BMV meter).
Is this because of the temperature compensation? In the manual the line in the schema is not higher then 14,7V
Is something wrong or is this normal?
Peter Polz avatar image
Peter Polz answered ·
If battery will be used under cold condition and you have tempsensor installed, then it's a normal tempcompensation
agnieta answered ·
Thank you for your answer. I think the temp in the motorroom was around 5-10 Celsius.
So it will not damage my battery’s?
