esbjorn avatar image
esbjorn asked
BMV-702 SOC/temperture
I have BMV-702 with temperature sensor together with LiFePo4
I usually use SOC between 95% -60%, to open / close relay, which starts charging at 60% and closes at 95%
Now I also want to close the charge below 0 degrees and test "High temp relay", but it does not work if I simultaneously use SOC.
Do you have any suggestions that will make both controls of the relay work
temperature compensation
Paul B avatar image
Paul B answered ·
Try connecting the BMV702 to your phone when its on the internet and upgrade the BMV702 to the latest firmware.
I presume that the temp relay option only appears when there is a temp sensor connected. as I have not seen this option before
esbjorn answered ·
Thanks for your comments. Yes, tempsensor connected.
Updated in connection with testing. Version BMV-702: v3.10
Zac Blodget avatar image
Zac Blodget answered ·
I'm hijacking an old thread here. Can the BMV-702 operate the relay based on SOC AND Battery temperature (assuming I buy and install the separate temp sensor cable) or is it one or the other?
Thanks,
