mimbeck avatar image
mimbeck asked
BlueSmart IP22 - 0.0A while loading
Hi - my IP22 shows that it is loading with 14,44V but with 0.0A. I am not an expert but this seems to be a problem. Also my battery monitor shows no incoming power. I now disconnected everything (only the IP22 is connected) and same result.
There is only one battery connected right now.
Any hints?
charger
Mark avatar image
Mark answered ·
Please check the fuse and anything else in the circuit - I suspect an open circuit somewhere...
You could also try to measure the voltage at the end of the DC leads with a multimeter or try to run a 12V load/light.
If these tests all turn out good then your battery is probably dead and has an internal open circuit.
mimbeck answered ·
Current status: a fuse in the + wire to the battery was not working correctly. Problems seems to solved. Thanks!
