rlentz avatar image
rlentz asked
With a second battery installed using only an Orion-Tr Smart Charger, can I use "hot" auxiliary outlets with the ignition key off?
I want to install an Orion-Tr Smart DC DC charger and a second battery as you show in your charger manual. Once installed, I want to use the "hot" accessories in my vehicle with the ignition key turned off. Will the smart charger use the second battery in this scenario?
battery charging
