danmannale avatar image
danmannale asked
Monitor midpoint voltage and temperature with mppt 100/50
As far as I understand it is not possible to connect a SmartSense Temperature sensor and the BMV Battery Monitor. So: is there a way to monitor both with the Victor equipment?
Another question: I have 4 Batteries, two in series parallel with the other two (24V). Is there a way to monitor both mid-points?
Thanks!
monitoring
Jaco Reinecke avatar image
Jaco Reinecke answered ·
Smart Battery Sense is a wireless battery voltage and temperature sensor for Victron MPPT Solar Chargers whereas the BMV is a separate part of the system, on the batts, to calculate mainly the SOC?
Or am I missing something?
Because the options we have to measure batt temps:
BMV712 can either monitor the midpoint, or the temp with its temp sensor.
VenusGX can also monitor the temp with its temp sensor.
And the MPII can also measure the temp of the batts, with its temp sensor.
