rwandering avatar image
rwandering asked
Victronconnect - No devices found
We packed up to leave a full hook up site this morning. I opened my victronconnect app on my iPhone to find a NO DEVICES FOUND message. The app looked a little different than the last time I used it so I assume it has updated. When I went to my bluetooth devices none of the Victron devices were connected and wouldn't connect when prompted. I deleted the devices and hard re-booted my iPhone, went back into bluetooth devices and they still were not visible. I checked all the the physical devices, battery monitor, mppt controller, and MultiPlus inverter and determined all were working. I turned off the inverter for 15 seconds and turned it back on but still no signal. It seems strange that all 3 devices would fail at the same time. HELP!
Bluetooth
rwandering answered ·
Ok it turns out that the app updated on my iPhone and when it did it turned off Bluetooth in the app. That setting is not visible in the app. I had to get to settings/VictronConnect and turn in bluetooth. Problem fixed. Thanks all
Hi @rwandering
Do you have another phone / tabled / laptop you can try?
not seeing at all usually is due to bluetooth being disabled on the phone.
What version of iOS do you have, and what version of VictronConnect?
ray-mont avatar image
ray-mont answered ·
@rwandering i had the same here yesterday
victronconnect version 5.26
solved it after switching GPS on , on the phone.
it only happened on my brand new Samsung s20 5g(Android 10) not on any other other device
ie ipad, Samsung a5 2017 nor on a Samsung s6(Android 7)
i presume it has a issue with android 10
Ray
gps off
gps on
ejrossouw avatar image ejrossouw commented ·
Indeed, for newer android versions location setting has to be on in this ludicrous implementation of nfc by google as discussed in this post before. I keep mine off so it renders some apps useless.
