Michael Riley avatar image
Michael Riley asked
Documentation for Victron Connect
@Guy Stewart (Victron Community Manager)
Hi Guy, Suggest at Paragraph 3.1 of the Victron Connect manual that you add the limitation for the VEBus BMS assistant... correction to my last version.
This edit update - the later info clearly identifies the VEBus BMS assistant under the lithium battery 'wizard' - as a limitation; note however I did not want the wizard as I knew what parameters I wanted.
Is this limitation for ALL assistants?
Cheers Mike
VictronConnectAssistantssoftware
VictronConnect Manual
Download for iOS / Android / Mac / Windows
VEConfigure Assistants manual
