p0lar avatar image
p0lar asked
BMV 712 hook up with charger on other end of trailer
My trailer has the batteries in front and the plugin in the back. I installed the shunt in the battery box in the front and hooked one end to the NEG of the battery and the solar panel/trailer load box to the other end of the shunt as well. I also hooked power from the POS to the shunt B1 and the midpoint of the two 6v batteries to B2.
My question is. there is a power supply in the rear of the trailer that has AC input from outside plug to a PC type power supply that has 12V cables that go directly into the power box also in the rear of the trailer. I think that ALSO charges and tops off the batteries in the front.
will this work correctly? will it show charging via this PC style AC power supply?
battery chargingBMV Battery Monitor
harold avatar image
harold answered ·
You should buy a simple regulated charger!
Victron BMV battery monitors product page
