chriss avatar image
chriss asked
Need Help to Install Victron Orion-Tr Smart 12/12-30A with Schaudt EBL 119
Next Week i will install the Victron Orion-Tr Smart 12/12-30A and a LIONTRON LiFePO4 12,8V 150Ah Battery. I have a Globecar Campscout B. In this Car is the EBL Schaudt 119 installed under the Seat from the Driver. At this Position there is also the Battery for the Engine. Under the Passenger Seat is the Place for the new LiFePO4 Battery (now at this Time there are two AGM Batterys).
The Victron Orion-Tr Smart 12/12-30A has an Option to detect that the Motor is running, so i do not need to search the D+ Line. But which Cables must i install from the Schaudt EBL 119 to the
Victron Orion-Tr Smart 12/12-30A and then from the Orion back to the Schaudt ?
I can not find a Guide for that Combination. In the Userguide are Configurations explained but i am afraid that i make a Mistake.
Please can you help me which Cables i and Configuration i must use ?
Greetings
battery charging
