Hello, I recently purchased a 24v , 16 amp Phoenix Battery Charger but it has no household plug on it; do I use 1mm2 , 3 core to wire to a standard plug?
The output wires I am fine with. Thank you for your help
Yes, these are - relatively low power so a 13amp UK plug or equivalent is fine. worst case below.
16amp x 27volts = 432 watt
432 wat t/ 220v ac = 1.96amps
Hi Jwfrary, thank you for your help. I am new at this so i wonder if you could clarify : you x 16amp by 27v to get the wattage, where as I thought I should x 16amp by 24v to find the wattage , as I have a 24v Battery charger....
14 People are following this question.
