kevin-haury avatar image
kevin-haury asked
VE.Direct LoRaWAN on a private network (without TTN)
I need to use a private network to connect the VE.direct module. I'm afraid to see it's only possible to connect on TTN network...
So :
- Can you explain where can I find the OTAA information for the commissioning ?
- Where I have to push the data and wich protocol I need to use ?
In case of it's not possible for you to aswer the question, can send me the datasheet with the codec of the sensor to decode the data myself ?
Thank you for your reply
LoRaWAN
kevin-haury avatar image kevin-haury commented ·
Can someone send me a technical contact ?
Thank you
Lasse avatar image
Lasse answered ·
Hi Kevin,
The VE.Direct LoRaWAN Module only supports the TTN network. Switching to a private network would require changes in the LoRaWAN module and on the server-side to get the data securely in VRM.
Best regards, Lasse
