jacola avatar image
jacola asked
ET340 via Modbus/TCP ?
Hello, i am new to Victron and want to set up a larger battery system 3 phase etc.
ET340 is already installed, but it is far away from the battery location, unsuitable to run long 485 connections.
Is there a way, has someone experience, to convince the GX controller to use Modbus/TCP to talk with the ET340 (via a modbus/TCP to RTU bridge of course),
or
Has anyone experience in or tried to bridge Modbus/RTU over IP (wifi, ethernet etc) ?
Johannes
Energy MeterModbus TCP
dayandnight avatar image
dayandnight answered ·
Hello @jacola,
I think I had a similar situation at my location "... is far away from the battery location ..." - I solved it at my location with a different energy meter the EM24 Ethernet version.
Without knowing your needs in detail I can only guess. Perhaps this would be possible for you, too? I just plugged EM24 into my network and I had to use ESS system / firmware version 2.60. Which is just now (June 2020) and today still a release candidate version of ESS but I am sure it will be soon released.
DayAndNight
