Hello Sirs,
It seems, that on dashboard "Solar kWh" reading is not correct.
If I compare this value to "Advanced" page MPPT solar yield readings, there is a big difference.
Am I wrong... or is this a little bug ? :)
Br, Kimmo
Hello Sirs,
Br, Kimmo
You need to take into consideration losses in the system for unit self consumption and heat and or cable losses dues to sizing or length and various other inefficiencies.
It seems like it may be specificly related to your physical system setup, as my system does not have this difference. Calculated for June 3.
15 People are following this question.
