samweigel avatar image
samweigel asked
BPP2 no longer detects MultiPlus
Hi, on my boat I have a 2-year-old Blue Power Panel 2 connected to a VE.Net Battery Controller as well as a 2-year old MultiPlus 12/3000/120 via VVC/VE.Bus. Recently the BPP2 abruptly dropped the MultiPlus from its device list, not able to add it back in Setup-Overview-System, resetting the BPP2 & even disconnecting its power no help. Tried switching RJ45 ports on both the BPP2 (VE.Bus ports) and the MultiPlus, no help, tried a new cable, no help. I don't see anywhere to reset the BPP2 to factory default settings, other than that I'm out of ideas. I know the MultiPlus can tell it is connected to the BPP2, because with its hard switch "ON" it stays off, until you disconnect the cable, then it turns on. I have not updated software on BPP2 or MultiPlus since installation 2 years ago., BPP version is 0x0107. Thanks, Sam
blue power panel
