fenix avatar image
fenix asked
Raspberry 3b running on 12v batteries Camper
Hi
How to you plug the Raspberry Pi to the 12V batteries?
RaspberryPi 3B with the 7 inches screen
i don't run any inverter
i would like to run on the 12V batteries but i know (i think)that the raspberry pi B has to run on 5.1V with 2.5 Amp
Do you have a StepDown Dc to DC?
What is your setup?
What kind of power supply ?
Tks
Raspberry Pibattery
Scott Bender avatar image
Scott Bender answered ·
You need a step down converter like: HOMREE DC-DC Converter Step Down Module 12V to 5V Micro USB Output Buck Power Adapter https://www.amazon.com/dp/B01MEESLZ6/ref=cm_sw_r_cp_api_i_TDB0EbQ5Q7XQ8
fenix avatar image
fenix answered ·
Scott Bender avatar image Scott Bender commented ·
Yes. That will work also.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
