Nev avatar image
Nev asked
Blue Smart IP22 30A Charger - Minimum 1 hour Absorption Time ?
The latest versions of the VictronConnect app now allows a multitude of settings via Bluetooth. Thank you.
I note that the minimum absorption time unless I have missed a setting is still restricted to 60 minutes minimum. Is this a firmware limitation or could it be reduced via a software update?
I use this charger with a 4 cell 300Ah LiFePO4 battery and have my Victron MPPT controller set to just 1 minute at 14.2V for the last 6 years of daily use. The battery has usually reached 100% SOC at that point.
The 1 hour minimum absorption period on this charger is just a little concerning and unecessary for our setup.
Neville
Bluetooth
Hi @Scubadoo,
Using the demo for the IP22 Blue Smart 30A charger, in Settings, Custom Charge Preset -> Advanced battery settings -> User defined -> Expert mode. I was able to set an absorption time of 1 minute.
Where did you find the limitation to 60 minutes?
mondeoman avatar image
mondeoman answered ·
I just tested the latest firmware on a Blue Smart IP65 12V / 10A.
The new features are great. The "digitally programmable" Power Supply mode is very useful around the shop.
However, it does not allow me to set Absorption Duration to less than 1 hour.
If you set it to anything less than 1h, when you press Ok, it automatically upgrades to 1h.
Slightly disappointed.
At C rates below 0.1C (e.g. a 10A charger on a 100 Ah battery), LiFePo4 batteries are already > 90% charged when reaching the Abs voltage. An additional 1 hour absorption may take you into overcharge territory. I could lower the Abs voltage and compensate with a 1 hr Absorption, but that increases the charging time.
marco-merchioni avatar image marco-merchioni commented ·
Hi mondeoman, I have the same problem with my Orion DC-DC charger, with te same C rate (30A-300Ah). How did you calculate the compensation Abs voltage/1h Absorption?
Thank you
Nev avatar image
Nev answered ·
Hi Guy
Using the setting in real mode. I have not tried the simulator mode yet.
Although I can adjust the "Maximum absorption time" setting to 1 minute or any number less than 1 hour with the slider it is not accepted when entering OK and always reverts back to 1 hour.
Thanks both,
It seems there is not a quick fix for this, the absorption time is indeed limited to 1 hour minimum. For now unfortunately you will have to work around it as best as you can.
Perhaps in the future the configuration options will be expanded further.
marco-merchioni answered ·
I have the same problem with my Orion 30A DC-DC Charger. I was thinking about buying a Blue Smart 30A, but really,I think at this point, I will wait for a solution or I wish to reconsider my choice.
