syfte avatar image
syfte asked
For a GX System w/BMS, what scenarios require separate physical charge/load disconnect wiring from the BMS?
In a GX system with the BMS connected via VE.Bus, do VE.Direct/VE.Can/VE.Bus devices need separate physical wiring to Remote ports (or controlling Battery Protect) to disconnect charge/discharge?
Am I correct in saying that in such a system, only devices not talking a Victron protocol need Battery Protects with Remote connected to the BMS?
gx device
