thompsondr1 avatar image
thompsondr1 asked
Charger moving to Float and not moving back
I will preface by apologizing for not being an electrical expert...but I'm running into a few issues. I have a Victron BMV 712, a Victron MPPT charge controller 100/30, 300 watts of solar and 200ah Battleborn batteries (all fairly new). My batteries were charging up to around 85% in Bulk then spending some time in Absorbtion and finishing in Float to 100%. Now they are switching to Float at around 80% and will not switch back to Absorbtion or Bulk for the remainder of that day. I have tested this by waiting until it goes to Float and turning on my appliances and running it down to 50% (all the while the MPPT stays in Float). The next day it cranks right back up in Bulk and goes up until about 80%. I am using the app and (think I have) configured my charge controller and BMV according to Victron instructions. What could be happening here and/or what information would need to hazard some guesses? Thanks!
battery charging
Hi @thompsondr1
Can you show a screenshot of your charging settings?
if you select 'expert mode' there is a setting for re-bulk voltage.
thompsondr1 answered ·
Here are pictures of the Battery screen from the MPPT and the BMV. Let me know if there was something else that would help. Thanks!
Of course after writing this yesterday it has spent the entire (super sunny) day on Bulk, even after the battery was 100% full hours ago. Maybe I’m just focusing on the wrong thing and the % full actually has no connection/correlation with what charge stage it should be in(?)
Hi @thompsondr1
voltage / current is your proof, if your battery monitor is not setup correctly, or connected properly, it can be wrong :)
Any chance you could be a little more specific about what I should check and what I should expect to see? And I do have a voltimeter.
about the BMV settings: charged voltage should be (close to) absorption voltage, so 13,2V is way too low and can cause the unit to sync to 100% too early
https://www.youtube.com/watch?v=4ReljfO3k6M
about charging: look at the voltage where it goes to absorption / float, does that correspond with the settings?
PS. 14.6V seems very high for a LiFePO4 battery, what is the minimum charging voltage according to the manufacturer?
