Hallo Community i have a Quattro 24/5000/120-2x100 . I have been trying to find the correct firmware update. my current firmware is 2648150. Can I use 264843 for my model? I'm not 100% sure here.
I assume you meant 2648431 as the number for the new firmware.
In general, if the first four numbers match (which your's do), it is ok to update.
Below is Victron's explanation of the firmware number:
VE.Bus Firmware numbering system
1941143
||-------> 19 is the family group number
||-----> 41 is the model: Quattro 24/3000/70-50/30
|||--> 143 is the firmware version
Family groups
18 No VE.Bus
19 VE.Bus - old microprocessor, 230VAC
20 VE.Bus - old microprocessor, 120VAC
26 VE.Bus - new microprocessor, 230VAC
27 VE.Bus - new microprocessor, 120VAC
Pat
hello,
i am currently checking the same issue. as far as i understand it is ok to update from 2641150 to 2641465 using the current version of ve_flash and a mk2-usb-adapter. or did i miss something vital.
how high is the chance of failure while updating. i am familiar with the procedure but have found some messages here about updates failing and inverters not working anymore...
thanks for your advice
jochen
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
Updating VE.Bus firmware, using VEFlash (Depreciated)
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
4 People are following this question.
