laurenceh avatar image
laurenceh asked
How do I get venus-data.tar.gz to be unpacked on reboot?
Platform: Venus OS Version 2.53 (see boot log attached below) Rpi-3
I have an SD card with a tar file made on a Venus GX raspberry pie but I don't think this is anything to do with the Raspberry pi platform as the process should be so simple.
When I reboot Venus the venus-data.tar.gz is not unpacked.
However execution of either of the scripts:
/etc/rc5.d/S30update-data.sh
or /etc/init.d/update-data.sh
Works fine and reports: "Updating /data with /media/sda1/venus-data.tar.gz"
And the contents are correctly installed on /data
What can be going wrong to disable the unpacking of venus-data on reboot?
I have identified in the log below where the update-data script should be running according to the numerical order of the scripts in the rc.5 directory (between the avahi and php-pfm.
Thu Jan  1 00:00:03 1970: hwclock: can't open '/dev/misc/rtc': No such file or directory
Sat May  9 11:29:14 2020: Sat May  9 11:29:14 UTC 2020
Sat May  9 11:29:14 2020: hwclock: can't open '/dev/misc/rtc': No such file or directory
Sat May  9 11:29:14 2020: Starting watchdog
Sat May  9 11:29:14 2020: INIT: Entering runlevel: 5
Sat May  9 11:29:14 2020: Configuring network interfaces... done.
Sat May  9 11:29:15 2020: Starting system message bus: Setting up watches.
Sat May  9 11:29:15 2020: Watches established.
Sat May  9 11:29:15 2020: /var/run/dbus/ CREATE system_bus_socket
Sat May  9 11:29:15 2020: Starting haveged: haveged: listening socket at 3
Sat May  9 11:29:15 2020: haveged: haveged starting up
Sat May  9 11:29:15 2020: ^[[1;34m[^[[1;32m  OK  ^[[1;34m]^[[0;39m
Sat May  9 11:29:15 2020: Starting bluetooth: bluetoothd.
Sat May  9 11:29:15 2020: starting DNS forwarder and DHCP server: dnsmasq... done.
Sat May  9 11:29:15 2020: hwclock: can't open '/dev/misc/rtc': No such file or directory
Sat May  9 11:29:15 2020: Starting syslogd/klogd: done
Sat May  9 11:29:15 2020:  * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
< The update-data script should run here>
Sat May  9 11:29:15 2020: ^[[A^[[74G[ ok ]
Sat May  9 11:29:15 2020: Starting php-fpm  done
Sat May  9 11:29:16 2020: Starting Connection Manager
Sat May  9 11:29:16 2020: Starting Hiawatha Web Server: hiawatha.
Sat May  9 11:29:16 2020: starting IPv4LL configuration daemon: avahi-autoipd... done.
Sat May  9 11:29:16 2020: starting resolv.conf manager: resolv-watch... done.
Sat May  9 11:29:16 2020: dbus[590]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Sat May  9 11:29:18 2020: Starting crond: OK
Sat May  9 11:29:18 2020: Checking available software versions...
Sat May  9 11:29:19 2020: dbus[590]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Sat May  9 11:29:19 2020: Active rootfs: 2
Sat May  9 11:29:19 2020: Active version: 20200405141454 v2.53
Sat May  9 11:29:19 2020: Backup version: 20200301205316 v2.51
Venus OSreboot
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
